Steve-534B46
4 years agoQuestaSim (Intel Starter) : Bad default binding for component instance "ALTLVDS_RX_component
I am trying to simulate a description containing the ALTLVDS_RX primitive.
I launch the simulation through Tools->Run simulation tool->RTL simulation
When I start the simulator with th...
- 4 years ago
Hello Steve,
We have a KDB about this error. Please check on the KDB below and follow the workaround suggested: Error (suppressible): (vsim-10000) Unresolved defparam reference to 'lvds_rx_reg_setting' in ALTLVDS_RX_component.lvds_rx_reg_setting
Hopefully this workaround will be able to resolve your issue.
Thank you
sstrell
4 years agoCan you show the code the error is referencing?
Steve-534B46
4 years agoHello,
Here are the files:
- HSSSB.vhd is the top level entity,
- receiver is a wrapper for the Data_rx entity generated by MegaWizard
- Data_rx is the ALTLVDS_RX IP customize through MegaWizard
Steve
