11 years agoQuestasim Altera libraries
Hi, I want to compile a project with Questasim -64 10.2c and this project (downloaded from opencores.org) contains some Altera components so I need Questasim libraries. I could use modelsim-AE ins...
11 years agoLook in the libraries tab in Modelsim AE. Look at the path of the libraries you need
Find the files in the correct folder Copy them to some other directory (you dont have to do this, but if you dont copy them, then you'll have to recompile them the next time you use modelsimAE) In Questa, either use vmap to the path: eg: vmap altera_mf /<mypath>/altera_mf/ or do it via the gui - right click - add library - fill in the boxes. right click on the added library and click refresh
