grspbr
4 years agoQuesta not fetching license
I've installed Quartus Prime Pro 21.3 but cannot get a license.
license, server, deamon - all up to date and working
Our IT has investigated and can't find a problem with computer, nor network, b...
DrNickels
4 years agoHi,
We are moving from DE0 Boards (Cyclone III) with Quartus 13.1 and vsim (one class) or modelsim-altera (another class), moving to
DE10-Lite boards (MAX10) with Quartus 21.1 and vsim / questa.
We've got the same issue as the OP. When I go to do a University Waveform File (or run Tools/Run Simulation Tool), I get a licensing error. We have the intelqsim license code.
Here is the output from the UWF run (vsim):
Determining the location of the ModelSim executable... Using: C:/intelFPGA/21.1/questa_fse/win64 To specify a ModelSim executable directory, select: Tools -> Options -> EDA Tool Options Note: if both Questa Intel FPGA Edition and ModelSim executables are available, Questa Intel FPGA Edition will be used. **** Generating the ModelSim Testbench **** quartus_eda --gen_testbench --tool=modelsim_oem --format=vhdl --write_settings_files=off version1 -c version1 --vector_source="U:/engr3181_work/tach_project/de10_tach/Waveform.vwf" --testbench_file="U:/engr3181_work/tach_project/de10_tach/simulation/qsim/Waveform.vwf.vht" Info: ******************************************************************* <snip snip> Completed successfully. **** Generating the functional simulation netlist **** quartus_eda --write_settings_files=off --simulation --functional=on --flatten_buses=off --tool=modelsim_oem --format=vhdl --output_directory="U:/engr3181_work/tach_project/de10_tach/simulation/qsim/" version1 -c version1 Info: ******************************************************************* Info: Running Quartus Prime EDA Netlist Writer <snip snip> Info: Quartus Prime EDA Netlist Writer was successful. 0 errors, 25 warnings Info: Peak virtual memory: 4689 megabytes Info: Processing ended: Thu Jan 27 16:09:33 2022 Info: Elapsed time: 00:00:14 Info: Total CPU time (on all processors): 00:00:01 Completed successfully. **** Generating the ModelSim .do script **** U:/engr3181_work/tach_project/de10_tach/simulation/qsim/version1.do generated. Completed successfully. **** Running the ModelSim simulation **** C:/intelFPGA/21.1/questa_fse/win64/vsim -c -do version1.do Unable to checkout a license. Make sure your license file environment variable (e.g., LM_LICENSE_FILE) is set correctly and then run 'lmutil lmdiag' to diagnose the problem. Unable to checkout a license. Vsim is closing. ** Error: Invalid license environment. Application closing. Error.
I've attached picture of the error when I try to launch questa from Tools/Run Simulation Tool as well as the license setup from the menu.
Here is the license setup from lmutil:
PS C:\intelFPGA\21.1\quartus\bin64> lmutil lmstat -a -c [email protected] lmutil - Copyright (c) 1989-2019 Flexera. All Rights Reserved. Flexible License Manager status on Thu 1/27/2022 16:04 [Detecting lmgrd processes...] License server status: 27006@ITS-Morris License file(s) on ITS-Morris: C:\Quartus\license.dat: ITS-Morris: license server UP (MASTER) v11.16.2 Vendor daemon status (on ITS-Morris): alterad: UP v11.16.2 Feature usage info: Users of 6AF7_00CB: (Total of 37 licenses issued; Total of 0 licenses in use) Users of 6AF7_00BC: (Total of 37 licenses issued; Total of 0 licenses in use) Users of 6AF7_0005: (Total of 37 licenses issued; Total of 0 licenses in use) Users of 6AF7_0079: (Total of 37 licenses issued; Total of 0 licenses in use) Users of 6AF7_00A2: (Total of 74 licenses issued; Total of 0 licenses in use) Users of 6AF7_0022: (Total of 37 licenses issued; Total of 0 licenses in use) Users of 6AF7_0011: (Total of 37 licenses issued; Total of 0 licenses in use) Users of 6AF7_0024: (Total of 37 licenses issued; Total of 0 licenses in use) Users of 6AF7_0025: (Total of 37 licenses issued; Total of 0 licenses in use) Users of 6AF7_0088: (Total of 37 licenses issued; Total of 0 licenses in use) Users of 6AF7_0095: (Total of 37 licenses issued; Total of 0 licenses in use) Users of ip_base: (Total of 74 licenses issued; Total of 0 licenses in use) Users of 6AF7_00BD: (Total of 37 licenses issued; Total of 0 licenses in use) Users of maxplus2: (Total of 37 licenses issued; Total of 0 licenses in use) Users of maxplus2verilog: (Total of 37 licenses issued; Total of 0 licenses in use) Users of maxplus2vhdl: (Total of 37 licenses issued; Total of 0 licenses in use) Users of quartus: (Total of 37 licenses issued; Total of 0 licenses in use) Users of 6AF7_00D8: (Total of 74 licenses issued; Total of 0 licenses in use) Users of 6AF7_0014: (Total of 74 licenses issued; Total of 0 licenses in use) Users of 6AF7_0034: (Total of 74 licenses issued; Total of 0 licenses in use) mgcld: UP v11.6 Feature usage info: Users of mgcvipae: (Total of 74 licenses issued; Total of 0 licenses in use) Users of mgcvipaeaxi: (Total of 148 licenses issued; Total of 0 licenses in use) Users of mgcvipaeaxi4: (Total of 74 licenses issued; Total of 0 licenses in use) Users of alteramtivsim: (Total of 74 licenses issued; Total of 0 licenses in use) Users of intelqsim: (Total of 37 licenses issued; Total of 0 licenses in use) PS C:\intelFPGA\21.1\quartus\bin64>
