nueeardente
4 years agoQuesta not accepting the license file.
I just installed Intel FPGA Lite 21.1 and for Questa I followed the instructions to create and install the license file (how-to-set-intel-license-file-environment-variable ).
Questa is una...
- 4 years ago
Hello Wani,
Thank you for your support.
I installed the Questa and Quartus in a different PC and it worked fine, so I think there is a configuration issue with the original computer (some other software interfering, etc).
Since I got it working in a different PC, I will close the issue here.
I appreciate your help.
Zawani_M_Intel
4 years agoDear nueeardente,
Thank you for using Intel FPGA Community forum.
For first workaround, can you check if you are using the newer daemon version 11.16.4.0? If not, you may want to upgrade to the newer version.
After updating the daemon version, please perform the server shutdown/kill all the license service and restart the server from the ground zero.
Can you have a try and do let me know if you face the same issue again.
Thanks!
Wani
