mindchasers
4 years agoQuesta Design Optimization Box has OK Disabled
I'm new to Questa, and I'm trying to change the visibility options available in the Design Optimization Box. However, the OK button is disabled, so I can't make any changes.
I have trie...
SyafieqS
4 years agoRoberts,
The "OK" button did not appear even after you select you file under the work library? Keep gray in color?
Is this issue intermittent or often? Would be great for a feedback, could be a bug.
Can you try to reinstalling the Questa and see if this can work.
