Diego2
5 years agoquartus::sta not working inside quartus_fit
Hello
I tried using quartus::sta commands in quartus_fit, but it doesn't even let me create a timing model. I'm not sure why it is even possible to load this package inside quartus_fit if one can't...
- 5 years ago
As stated in the error message, the command you are trying to execute is only supported in the quartus_sta but not quartus_fit. You have to use the supported Quartus executable to execute the commands in certain packages.
KhaiY
sstrell
5 years agoYou can load any package for any executable, but as you found that doesn't mean you can do anything with it. What do you want to be able to do?
- Diego25 years ago
That seems to be the case, although the user guide states the following
This package is loaded by default in the following executables: quartus_fit quartus_staI want to be able to run timing analysis commands after finishing the planning phase without having to change tools.
