ZVere
5 years agoQuartusLiteSetup-18.1.0.625-windows : License problem
I downloaded QuartusLiteSetup-18.1.0.625-windows from https://fpgasoftware.intel.com/18.1/?edition=lite
and installed it successfully under windows 7,10.
When I worked under windows 10...
KhaiChein_Y_Intel
5 years agoHi Zvika,
I could help to report this to our engineering team if it is reproducible in the latest version of the Intel Quartus Prime software as some bugs in the older version will be fixed in the newer version. I understand that you could not upgrade to the latest version. If you could and the error is reproducible, I will help to file a report case to the team. If it is not feasible, could you use the workaround - Use Win 10 or Win 7 with internet ?
KhaiY
- ZVere5 years ago
Hi KhaiY,
With Internet (win10) it works fine.
But when I installed the same version under win7 without Internet, I got the error.
Is there any log I can send ?
Thank you,
Zvika
