QuartusII Programmerのコマンドラインでのプログラム
QuartusII Programmerのコマンドラインでのプログラムでコマンド実行すると直ぐに終了してしまい書込みできませんでした。
考えられる要因はあるでしょうか?
-----<ここから>-----
C:\altera\13.1\qprogrammer\bin>quartus_pgm --cable="USB-Blaster [USB-0]" --mode
=JTAG -o pv;CPM_FPGA_20190313_v2.11.pof
Info: *******************************************************************
Info: Running Quartus II 32-bit Programmer
Info: Version 13.1.0 Build 162 10/23/2013 SJ Full Version
Info: Copyright (C) 1991-2013 Altera Corporation. All rights reserved.
Info: Your use of Altera Corporation's design tools, logic functions
Info: and other software and tools, and its AMPP partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Altera Program License
Info: Subscription Agreement, Altera MegaCore Function License
Info: Agreement, or other applicable license agreement, including,
Info: without limitation, that your use is for the sole purpose of
Info: programming logic devices manufactured by Altera and sold by
Info: Altera or its authorized distributors. Please refer to the
Info: applicable agreement for further details.
Info: Processing started: Thu Mar 28 11:07:09 2019
Info: Command: quartus_pgm --cable="USB-Blaster [USB-0]" --mode=JTAG -o pv;CPM_F
Info (213045): Using programming cable "USB-Blaster [USB-0]"
Info (213011): Using programming file CPM_FPGA_20190313_v2.11.pof with checksum
0x5493F610 for device CFI_256MB@1
Info (209060): Started Programmer operation at Thu Mar 28 11:07:11 2019
Info (209061): Ended Programmer operation at Thu Mar 28 11:07:11 2019
Info: Quartus II 32-bit Programmer was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 205 megabytes
Info: Processing ended: Thu Mar 28 11:07:11 2019
Info: Elapsed time: 00:00:02
Info: Total CPU time (on all processors): 00:00:02
-----<ここまで>-----
1 Reply
- Abe
Is the device getting configured? What is the size of the generated POF file? Disconnect the USB blaster cable , re-connect it and then try again.
