Altera_ForumHonored Contributor14 years agoQuartusII Error Message, ask for help, Thanks! Hi, everyone. Thanks for reading and kindly help me! I am using QuartusII +Stratix to try to build up a circuit. In the verilog code, I used "generate" function to generate N identical parallel sub-m...Show More
Altera_ForumHonored Contributor14 years agoYes, it seems this is the problem. Thank you very much for your kind help! :):)
Recent DiscussionsInvalid license key (inconsistent authentication code)Regarding the issue of UFM not startingram retimingReset Release IP for Agilex needs Stratix 10 device files installed!Licensing ‘Know-How’ Guide
