Quartus WSL and multi-user Windows Domain
- 5 years ago
Hi Eric,
I would recommend you to Linux env as it is more flexible. For now there is no work in progress for WSL multi-user in Window. You can use open source Virtual Machine as a workaround on Window.
Hi Eric,
Note: Starting with the Nios® II EDS in the Intel® Quartus® Prime Pro Edition software version 19.2 and Intel® Quartus® Prime Standard Edition software version 19.1, the Cygwin component in the Windows* version of Nios II EDS has been removed and replaced with Windows Subsystem for Linux(WSL)
Referring to above note, should not be any issue as there is no need to install WSL for older version(I guess this is what you meant by older version) and therefore students can get accessed to Quartus.
- EricP6 years ago
Correct the older versions use Cygwin and don't need WSL. However, we're jumping onto some new dev boards and want to jump to a newer version of Quartus. Students also tend to download the current version and if we're running something 4+ years old - it doesn't look good! For instance we were using QSys well after SOPC Builder became the norm and students would come back from workterms having used SOPC builder ....
If we do not jump to a newer version of Quartus within this development cycle - it will have to happen. Hopefully there is a work around for this - or one is in the works?
