10 years agoQuartus Waveform simulator
All, I have upgraded to Quartus Prime 16 Lite and have tried to recompile an old existing (simple) circuit that I used in Quartus II Web 9.0. It seems to compile fine but where did the simple Wav...
10 years ago --- Quote Start --- Thiago, Thanks for the reply. Yeah.... I've started to slowly dig into it to try to get it to work with my old designs... I guess I don't like change.... but there again, I only do 1-2 designs every 3-5 yrs. so I can't keep up with the technology. Every time I do a new design, I have to learn most new things from the ground-up. Thanks again, Keith --- Quote End --- Modelsim is hardly new (been around 15+ years) , and not going away anytime soon. If you can learn to use it, then you'll be able to do much more thorough tests on your design and because all simulators are basically the same you'll basically know how to use Cadence and ActiveHDL too.
