Quartus warning TMC-20050
- 4 years ago
See my other reply to you, but this looks like a message from the Design Assistant.
Typically, in order to infer memory block resources from RTL code instead of implementing RAM in logic blocks, all inputs must be registered. You'd want to check the device handbook for your targeted device to see if this is the case for you. The Design Assistant is indicating you are not doing this on one or more memories.
- pRob4 years ago
thanks for the answer!
