Quartus warning RES-50005
- 4 years ago
I am presuming the message in this and your other post are from the Design Assistant, not the Quartus compiler. The Design Assistant checks that you are following best practices in your design. You don't have to fix the issues found by the Design Assistant, but it's a good idea to review them and possibly act on them.
My guess for this message is your target device is a Stratix 10 or Agilex with Hyperflex. As such, you want to try to avoid using asynchronous resets as much as possible to allow for more retiming opportunities into the hyper-registers by the hyper-retimer stage of the compiler.
- pRob4 years ago
Thanks for you answer. Very useful!
