Christian_Woznik
4 years agoQuartus uses more DSP than available
Hello, I have a design that does a fair amount of multiplications. As far as I can see Quartus uses both DSP slices and ALMs to implement those, as the DSP report only shows a small fraction of a...
jozephka99
Contributor
4 years agoDo you have IPs in your design? Quartus use DSP blocks to execute some IPs. How do you do multiplications? Maybe you can use same IP instead of multiple IPs. This can solve your problem.
