9 years agoQuartus text editor quotation marks incorrect
I recently started using Quartus 16.1 on Ubuntu and I noticed a very annoying thing. When I want to assign some bit(s) to a std_logic(_vector) I use the ' or " characters. Quartus however, as t...
9 years agoIs this the first you're seeing this issue? Does it cause a problem when you try to compile your code or is it just aesthetics?
It sounds more like a keyboard/language/OS issue that with the text editor.
