User1578992947036356
6 years agoQuartus SRAM Generation
I am generating SRAM through Quartus Prime. I want to generate a SRAM that can read out data after write access. That is if I write 0xff to address 0 , data out will be 0xff after write access is d...
RichardT_altera
6 years agoIf you are using DE-series board, you can start by referring to the SRAM tutorial and Write to SRAM tutorial. Hope it helps.
