Quartus Programmer SW, 2 SW versions on the same PC
- 5 years ago
Hi
Please find my response below:
1. can be add somehow in the old Quartus SW (13.0.1) to be able to
program the Cyclone 10 FPGA? if yes how?
No
2. If I purchase the Alter Blaster 2 (PL-USB2-BLASTER) download cable
and used only with the latest Quartus SW (20.1.1) still i will have the
same issue?
I think this a good idea. The reason is blaster 2 and blaster 1 have different driver and they are not the same.
Bruce
The old devices are Cyclone 2 FPGA (EP2C20F484, EP2C35F484,...) and the new device is Cyclone 10 (10CL080YF484I7G) FPGA.
The idea is that to not do any modification for the test SW which are for the old devices and is working with the old Quartus Programmer SW because there are several test flow SW which then will require to update the path of the CLI app (quartus_pgm.exe) of the Quartus Programmer SW to point the new Quartus Programmer SW and than also we will need to re-validate the test system in the manufacturing line.
So I have to find an alternative solution for this issue.
If we purchase an Alter Blaster 2 (PL-USB2-BLASTER) download cable and used only with the latest Quartus SW (20.1.1), then still I will have the same issue?
The cable has nothing to do with it. That's just a JTAG bridge. The newer cable supports USB 2.0.
So you're saying the old Programmer doesn't see the C10 device on the JTAG chain, even after you click Auto Detect? If it doesn't, and you can't switch to the newer version of the Programmer, then there's not much you can do.
