JHaye4
5 years agoQuartus programmer initcfg does not work when using a .cdf file
When running the programmer from the command line with the command: quartus_pgm --initcfg test.cdf The FPGAs that I am programming do not get configured when the programmer exits like it says...
Zak
5 years agoHello, I have the same EXACT problem.
I'm running in Active Serial mode with a EPCQ device.
The flash is programmed correctly. I'm using quartus_pgm command with a .cdf file generated with Quartus 20.1. This loads the Factory Default Enhanced SFL Image in the FPGA in order to program the flash memory.
Everything works except the --initcfg option of quartus_pgm.
I'm using a Cyclone V, 5CEFA4U19I7N.
Can you help me?
