JHaye4
5 years agoQuartus programmer initcfg does not work when using a .cdf file
When running the programmer from the command line with the command: quartus_pgm --initcfg test.cdf The FPGAs that I am programming do not get configured when the programmer exits like it says...
YuanLi_S_Intel
5 years agoWhat about the MSEL pin? Have you changed that to Active Serial mode? What is the device you are using?
