JHaye4
5 years agoQuartus programmer initcfg does not work when using a .cdf file
When running the programmer from the command line with the command: quartus_pgm --initcfg test.cdf The FPGAs that I am programming do not get configured when the programmer exits like it says...
JHaye4
5 years agoI want to use the quartus_pgm command with a chain description file (.cdf) as per this line in the scripting manual you attached:
The quartus_pgm command details the option --initcfg, the description of that option in the scripting manual you linked is:
So, when I run the command:
quartus_pgm --initcfg filename.cdf
I expect the configuration devices to automatically configure when the programmer is finished, but it does not happen.
JHaye4
5 years agobump
