JHaye4
5 years agoQuartus programmer initcfg does not work when using a .cdf file
When running the programmer from the command line with the command: quartus_pgm --initcfg test.cdf The FPGAs that I am programming do not get configured when the programmer exits like it says...
YuanLi_S_Intel
5 years agoI am glad that you can program JIC now and understand that we cannot use the command with a .cdf file.
Please let me know if any help needed. Else i will proceed with case closure. Thank You.
JHaye4
5 years agoThe issue is that the quartus_pgm command does not behave as described in the scripting manual when using a .cdf file. Surely an issue should be raised to at least investigate this behaviour and possibly to remedy this issue.
