15 years agoQuartus Programmer "FACTORY" mode command
Hi All:
We have a new board that just came in with a Cyclone III LS device: EP3CLS150F484. This is the first LS design we've done. We are having a cpu program the device though using the Fast Passive Parallel (FPP) method. The configuration appears to complete successfully, but the design does not appear to function (To the point I can not even turn on an LED). I've already found that we had to turn off bitfile compression in FPP mode. However the question is: When I try to program the bitfile through JTAG, I'm getting the error message : Expected JTAG ID code 0x027030DD for device 1, but found JTAG ID code 0x00000000. I've searched here and on the Altera Website, and they are basically saying the design security has the device locked and and need to send the "FACTORY" command to program the device through JTAG. I get this response regardless if I've previously programmed the device at powerup or not. Which doesn't seem correct. (Should be unlocked at POR unless). However JTAG seems to identify the device correctly, and the JTAG tests work in the Quartus II programmer.. Is there a way to make the Quartus II programmer send the FACTORY command? I don't see any switches to make this happen in the GUI. The SOF file was built using Quartus II 9.1 sp1, But I've tried both the 9.1 sp1 programmer, and the 10.1 sp1 programmer with the same results. Thanks.. Pete
