10 years ago
Quartus Programmer 16.0 Linux can't run on Fedora 23
I install Quartus Prime Programmer 16.0 for Linux on Fedora 23. When try run it I see error:
$ altera/16.0/qprogrammer/bin/quartus_pgmw
*** Fatal Error: Illegal Instruction
Module: quartus_pgmw
Stack Trace:
0xce260: std::vector<DEV_PART_DESC*, std::allocator<DEV_PART_DESC*> >::_M_fill_insert(__gnu_cxx::__normal_iterator<DEV_PART_DESC**,
std::vector<DEV_PART_DESC*, std::allocator<DEV_PART_DESC*> > >, unsigned long, DEV_PART_DESC* const&) + 0x140 (ddb_dev)
0xf9b72: DEV_FAMILY_INFO_MGR_BODY::DEV_FAMILY_INFO_MGR_BODY() + 0x1e2 (ddb_dev)
0xcd761: DEV_FAMILY_INFO_MGR_BODY::get_instance() + 0x21 (ddb_dev)
0xba3c9: DEV_FAMILY_MANAGER::DEV_FAMILY_MANAGER() + 0x9 (ddb_dev)
0xf73a: call_init.part.0 + 0x9a (ld-linux-x86-64.so.2)
0xf84b: _dl_init + 0x8b (ld-linux-x86-64.so.2)
End-trace
Full strace log: http://paste.fedoraproject.org/376087/37098314
My glibc version glibc-2.22-17.fc23.x86_64.
With Programmer 15.0 I have no problem.
How I can solve this problem?
    Hi Vascom, I recently installed Quartus 16.0 on Linux Mint box, is your version full or Lite? If lite how you obtained a licence?
    I still mantain installed version 15.0 Web Edition 15.1.1Lite so I immediately got back to 15.1.1 ( and sometimes I fell desire to switch back to 15.0)
    One month ago 15.1.1 repeatedly asked for a licence file then stopped asking for it and continued to work fine but slow, now I need disconnect network or isolate application from internet otherwise project take 30 minutes than 2 to compile out with all cpu cores idling and no apaprent I/O activity.
    Best regards
    Roberto
    I am install only Quartus programmer. It is not requires licence at all.
    On recently released Fedora 24 I have the same problem.
