Quartus Pro 25.3 crash using rhel7/8
- 8 months ago
Hi all,
The KDB link had been live check https://community.altera.com/kb/knowledge-base/why-do-i-unexpectedly-observe-intermittent-ddm-errors/349714
We are seeing a very similar issue on Windows with Quartus Prime Pro 25.1.1 Build 125 + Patch 1.03.
Compilation (Analysis & Synthesis) freezes reproducibly depending on the system time:
Before ~11 AM: compilation always completes normally.
After ~11 AM: the first compilation attempt of the day hangs indefinitely.
This happens even:
– immediately after reboot,
– on weekends,
– with all db/, qdb/, and temp folders deleted,
– using both GUI and quartus_sh --flow compile,
– with Platform Designer closed or open.
We confirmed that if we manually set the system clock back to the morning (e.g., 08:00), the same project compiles successfully again.
If we restore the real time → the freeze returns.
This looks very similar to the recent reports of unexpected freezes in various Quartus 24.x–25.x versions starting around mid‑January 2026.
