aegeus
4 years agoQuartus Pro 21.1 Error in generating emif s10 example design
Hi all,
I'm generating a Stratix 10 EMIF example design on windows 10, tools version is Quartus Pro 21.1, I applied the "DDR3-1333H CL9 Component 1CS 4Gb(256Mb x 16)" presets, then generate the exa...
aegeus
4 years agoHi AdzimZM_Intel,
Thanks for your advise,I found the reason for this issue,it's a windows environment variable problem。
I had install the quartus 16.1 before, when i install quartus 21.1,the environment variable on my PC still 16.1, Just now i checked my environment variable,added a “IP_ROOTDIR” variable,change “QUARTUS_ROOTDIR” and “SOPC_KIT_NIOS2” to the real install path,then I successed to generate the example design.
I should check the windows environment at the first time, still thanks a lot for your adivise.
