Quartus Pro 21.1 Error in generating emif s10 example design
Hi Sir,
It's strange to have this kind of error.
Does the Quartus attempted to crash somehow in the middle of compilation or during generating process?
Do you see similar issue when generating the example design for Agilex device as well?
Do you able to migrate the design from Quartus 18.0 to Quartus 21.1?
I will provide a S10 example design and hopefully you can run the compilation.
Adzim
some additional info:
--No crash happens, and project compilation is good, but generating example process got errors. it looks like a example design generating issue.
-- I tried Agilex device example design generating just now, got the same errors as S10( I attashed the error logs below), but arria10 device's example design generating is good, no error.
--Not done yet, i will try it later, need to install a Quartus prime pro 18.0.
--I tried a full complile with your S10 example design, it's good.
