Quartus Pro 21.1 Error in generating emif s10 example design
Hi Sir,
It's strange to have this kind of error.
Does the Quartus attempted to crash somehow in the middle of compilation or during generating process?
Do you see similar issue when generating the example design for Agilex device as well?
Do you able to migrate the design from Quartus 18.0 to Quartus 21.1?
I will provide a S10 example design and hopefully you can run the compilation.
Adzim
- AdzimZM_Altera4 years ago
This is the qar file for S10 example design.
Please let me know if you can compile this design.
- aegeus4 years ago
Hi AdzimZM_Intel,
Sorry for the late reply.
I had a full complie with your S10 example design, tools Version 21.1.0 Build 169 03/24/2021 SC Pro Edition, on window 10 x64.
Complile flow looks nothing wrong with it.
- aegeus4 years ago
some additional info:
--No crash happens, and project compilation is good, but generating example process got errors. it looks like a example design generating issue.
-- I tried Agilex device example design generating just now, got the same errors as S10( I attashed the error logs below), but arria10 device's example design generating is good, no error.
--Not done yet, i will try it later, need to install a Quartus prime pro 18.0.
--I tried a full complile with your S10 example design, it's good.
- aegeus4 years ago
--I migrated a example design from 18.0 to 21.1, failed to update the IP.
