Waveform
7 years agoQuartus Pro 18.1. "Open selected entity" doesn't work.
Hello! In Quartus Prime Pro 17.1, the menu item “Open selected entity” is always gray. Quartus 18.0 and 18.1 has the same problem. So, I can not browse in my verilog code. This element is always in...
Waveform
7 years agoWhen I select and right click on entity in HDL code this menu item should be active, like it is in Quartus Prime Standart. And it was always working, except Quartus Prime Pro, starting from 17.1.
