bitstreamer
5 years agoQuartus Prime Standard Edition "Remove IP Component from Project" Greyed out
Using Quartus Prime Version 20.1.0 Build 711. In the Project Navigator with IP Components selected, when I right click to remove an IP Component listed, "Remove IP Component from Project" is greyed o...
SyafieqS
4 years agoJoe,
This could be due to file permission as it not allowed to to remove the file. Need to check on the directory/path as well might need to config chmod (if you are linux user) to give permission.
