bitstreamer
5 years agoQuartus Prime Standard Edition "Remove IP Component from Project" Greyed out
Using Quartus Prime Version 20.1.0 Build 711. In the Project Navigator with IP Components selected, when I right click to remove an IP Component listed, "Remove IP Component from Project" is greyed o...
SyafieqS
5 years agoJoe,
Possible to attached the qar here? let me me check at my end?
Alternatively, you may removed the IP by commenting it in qsf as a workaround. No need to delete the directory of the IP.
bitstreamer
5 years agoUnfortunately can't. I'll try and create a similar project.
