MRigh4
5 years agoQuartus Prime Standard 20.1 Crash
I have the following problem with my project on Quartus Prime Standard version 20.1. During the Fitting task, the tool isn't able to proceed due to an internal error. The following is the re...
MRigh4
5 years agoHi Nurina, disabling the LUT to RAM conversion as you suggested prefents the tool from crash but unfortunately my design requires an amount of RAM that make it not possible for the fitter to end using only M20K blocks. In fact now I have the following error that prevents the fitter to proceed:
Error (170048): Selected device has 2131 RAM location(s) of type M20K block. However, the current design needs more than 2131 to successfully fit
Considering the amount of memory required by the design (77% of the total available memory bits) I thought that it was possible to implement it on that device (10AX066K4F35I3SG).
Do you have any other suggestion?
Thank you very much.
