Quartus Prime software quit unexpectedly during Analysis & Synthesis
I run your design and got the below internal error.
Could you help to confirm? It is slightly different from the previous post. Line: 1143 vs 1142
Internal Error: Sub-system: QIS, File: /quartus/synth/qis/qis_parallel_helper.cpp, Line: 1142
FAILED in creating pipe ul_pipe_rtl_0_IHJikj with error code 12
Stack Trace:
Quartus 0x161acc: SYNTH::QIS::AUTO_PARTITION_MANAGER::optimize_in_helper_proccesses(SYNTH::QIS::OPTIMIZATION_STAGE) + 0xaea (synth_qis)
Quartus 0x163e05: SYNTH::QIS::AUTO_PARTITION_MANAGER::optimize_on_same_machine(SYNTH::QIS::OPTIMIZATION_STAGE) + 0x13 (synth_qis)
Quartus 0x163eef: SYNTH::QIS::AUTO_PARTITION_MANAGER::optimize_partitions_in_parallel(SYNTH::QIS::OPTIMIZATION_STAGE, bool) + 0xd (synth_qis)
Quartus 0x17d7c8: SYNTH::QIS::SYNTHESIS_FLOW::run_parallel_rtl_in_helper_processes(BASEX_ELAB_INFO_CORE*) + 0x1d0 (synth_qis)
Quartus 0x18439f: SYNTH::QIS::SYNTHESIS_FLOW::high_level_synthesis() + 0x361 (synth_qis)
Quartus 0x184709: SYNTH::QIS::SYNTHESIS_FLOW::run_current_phase() + 0x161 (synth_qis)
Quartus 0x184cef: SYNTH::QIS::SYNTHESIS_FLOW::run_full_flow(std::string const&, bool) + 0x3e1 (synth_qis)
Quartus 0xdd216: QIS_RTL_STAGE::IMPL::synthesize(QHD_PARTITION&, bool) + 0x468 (synth_qis)
Quartus 0xdd42d: QIS_RTL_STAGE::synthesize(QHD_PARTITION&, bool) + 0xf (synth_qis)
Quartus 0x7c071: qis_synthesize + 0x20e (synth_qis)
Quartus 0x4c942: TclNRRunCallbacks + 0x42 (tcl8.6)
Quartus 0x4de7b: TclEvalEx + 0x68b (tcl8.6)
Quartus 0xf3f0e: Tcl_FSEvalFileEx + 0x25e (tcl8.6)
Quartus 0xf3ffe: Tcl_EvalFile + 0x2e (tcl8.6)
Quartus 0x1eb68: qexe_evaluate_tcl_script(std::string const&) + 0x39c (comp_qexe)
Quartus 0x201fe: qexe_do_tcl(QEXE_FRAMEWORK*, std::string const&, std::string const&, std::list<std::string, std::allocator<std::string> > const&, bool, bool) + 0x3f3 (comp_qexe)
Quartus 0x21257: qexe_run_tcl_option(QEXE_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0x5ca (comp_qexe)
Quartus 0x474d9: QCU::DETAIL::intialise_qhd_and_run_qexe(QCU_FRAMEWORK&, FIO_PATH const&, std::string const&, std::string const&, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0x99 (comp_qcu)
Quartus 0x4c37e: qcu_run_tcl_option(QCU_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0x2a3 (comp_qcu)
Quartus 0x4081c3: qsyn2_tcl_process_default_flow_option(ACF_VARIABLE_TYPE_ENUM, char const*) + 0x499 (quartus_syn)
Quartus 0x2538b: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x8c2 (comp_qexe)
Quartus 0x407beb: qsyn2_main(int, char const**) + 0x139 (quartus_syn)
Quartus 0x44d56: msg_main_thread(void*) + 0x10 (ccl_msg)
Quartus 0x46377: msg_thread_wrapper(void* (*)(void*), void*) + 0x86 (ccl_msg)
Quartus 0x214a8: mem_thread_wrapper(void* (*)(void*), void*) + 0x98 (ccl_mem)
Quartus 0xcca5: err_thread_wrapper(void* (*)(void*), void*) + 0x1e (ccl_err)
Quartus 0xad55: thr_thread_wrapper + 0x15 (ccl_thr)
Quartus 0x46259: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0x148 (ccl_msg)
Quartus 0x407d23: main + 0x26 (quartus_syn)
System 0x20765: __libc_start_main + 0xf5 (c)
Quartus 0x407a09: _start + 0x29 (quartus_syn)
End-trace
