emery
4 years agoQuartus Prime Programmer: How to integrate ekp into pof for programming Max10 FPGA
UG-M10CONFIG 2021.07.02 Intel® MAX® 10 FPGA Configuration User Guide page 53 states:
3.8.3.2. Integrate the .ekp into .pof Programming To integrate the .ekp into .pof and program both altogether u...
YuanLi_S_Intel
4 years agoFrom your explanation above, are you saying that you can programmed the integrated encrypted POF, after that, when programmed another integrated encrypted POF with different key, it failed?
emery
4 years agoHi @YuanLi_S_Intel,
Yes. I program the Terasic DE10-Lite board with a single file integrated encrypted POF and this works, then I try to do the same again, with a different key, single file integrated encrypted POF and it does not program. However it will program if I send individual EKP and POF files.
Cheers
