Quartus Prime Pro Run RTL Simulation
- 5 years ago
I believe you were referring to the Nativelink Simulation feature which is supported only in the Quartus Standard and Lite version. In the Quartus Pro version, it is not supported.
For the Quartus Pro, simulate using the Scripted Simulation Flows. You may checkout the document link below on how-to simulate.
https://www.intel.com/content/www/us/en/programmable/documentation/gft1513990268888.html
Yes, I was mentioning NativeLink, thanks. Another question of mine appeared after your response.
I was already looking at the document that you mentioned but unfortunately I couldn't find what I was looking for. Is there a feature in Quartus Pro that automatically generates scripts to simulate my design in QuestSim? I do not want to create library and compile every design files by hand on QuestaSim. I saw there are some features for IP Cores but I did not use any IP Core in my design, so I cannot generate msim_setup.tcl file. Thanks in advance.
Quartus Pro does not have that feature which generate script for you. You need to write your own *.do file.
Just like ModelSim Macro File (*.do) is generated in the <project_directory>\simulation\modelsim directory while running the NativeLink feature. You could refer back to how the *.do written/generated in Quartus Standard version.
