Quartus Prime Pro and Questasim
I use Quartus Prime Pro and Questasim. I have a basic design that has two modules (counter and PLL IP). After Analysis and Elaboration -> Generate Simulator Script for IP, I open Questasim and enter necessary commands to transcript as mentioned in ug-qpp-tp-simulation.pdf. Simulation starts, modules are seen but there is no signal for visibility. For full visibility, I enter "vopt" command but Questasim gave an error that fourteennm_clk_divider.v in PLL IP is not defined. What is wrong that I made?
- EngWei_O_Intel
Hi Samet Caglan
Can you share us the design or at least the design files with issue and the script that you set up?
Eng Wei
- EngWei_O_Intel
Hi
We do not receive any response from you to the previous reply that have been provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Eng Wei
