yussuf_khalil
4 years agoQuartus Prime Pro 22.1 crashes when trying to use Signal Tap Logic Analyzer
Whenever I try to start the Signal Tap Logic Analyzer in a project using the Stratix 10 DX FPGA, Quartus will unconditionally crash with one of the following stack traces. This happens a few seconds ...
yussuf_khalil
4 years agoSorry for the late reply. I've found that Signal Tap works fine in Quartus 22.2 (whereas it's still not working properly for me in 22.1), so that issue is probably solved for me. However, can you elaborate on a possible solution for the .qdb file issue? I have seen the long loading times in several different projects. Is it a viable (and safe in terms of data loss) solution to delete the .qdb file and recompile the whole project?
