yussuf_khalil
4 years agoQuartus Prime Pro 22.1 crashes when trying to use Signal Tap Logic Analyzer
Whenever I try to start the Signal Tap Logic Analyzer in a project using the Stratix 10 DX FPGA, Quartus will unconditionally crash with one of the following stack traces. This happens a few seconds ...
RichardT_altera
4 years agoI think there is something wrong with your .qdb file in your project.
I cant seem to compile the project until I removed the .qdb file and set the preservation level to Not Set in the design partition window. I then able to open the project in a short loading time afterwards.
I tested a few times with the signal tap and it do not crash at all. Unfortunately, I am not able to help you if this is an intermittent issue.
