yussuf_khalil
4 years agoQuartus Prime Pro 22.1 crashes when trying to use Signal Tap Logic Analyzer
Whenever I try to start the Signal Tap Logic Analyzer in a project using the Stratix 10 DX FPGA, Quartus will unconditionally crash with one of the following stack traces. This happens a few seconds ...
RichardT_altera
4 years agoDoes the Quartus exit with a specific project/design? Will it re-occur if run with different design?
If so, could you help share your project .qar as the engineering team will need it to debug the issue.
Could you try to run the Quartus software as administrator and see if the issue occur?
yussuf_khalil
4 years agoIndeed this issue only seems to occur with this specific project. Signal Tap works fine when using an example project generated through Platform Designer. Running Quartus as administrator does not help. I can share the .qar file, however, I'd prefer to do so privately. Can you give me an e-mail address or another means of communication where I can send the file to?
