Quartus prime pro 20.3 installation failure on windows machine?
- 5 years ago
Hi Anil,
Yes, I had checked and confirmed it the the default format of part 2 file for 20.3 is .qdz. Can you cut the "_2" and try to rerun the installation
Hi Anil,
I suspect the issue is because the quartus_part2-20.3.0.158_2.qdz file. This might be a mistake as it should be an application file not device file. I wonder if you can change the format .qdz to .exe (renaming it but I don't can) for testing purpose and rerun the installation and let me know the update. I will report this issue will let you know once it has been fixed.
I also got the same thought of renaming .qdz to .exe on that day itself. But the same error repeated again.
I am familiar that windows installer should be .exe and altera device support comes with .qdz format.
- SyafieqS5 years ago
Hi Anil,
Can you try to download the Quartus with multiple file download option as an alternative for now? The size not too big as complete download and it also include the Quartus Prime part 2. Let me know if you are okay and also the part 2 format, if it still .qdz or .exe. with this option.
- anilinintel5 years ago
hi,
No hurry. please try to give the solution to the Original Post.
Multiple file download of 12 GB .tar file is heavy for me. If its not too big for you. please download and cross verify the part2 file format.
But I'm sure that the same error may encounter for this approach as well.
Hi Anil,
Noted and appreciate it. I have filed the report INC011990526 ticket. Will let you know once there is any update.
