Quartus Prime Pro 19.3 installation hangs
Hi all,
while installing Quartus Prime Pro version 19.3 I noticed that the installer hangs at the same point, not completing the installation. Please see the attachment.
I tried to install only the minimal Quartus packets (QuartusProSetup-19.3.0.222-linux.run and QuartusProSetup-part2-19.3.0.222-linux.run) as suggested here but it doesn't solve the issue.
I am currently running on this system:
Platform: linux64
OS name: Ubuntu 16.04.6
OS version: 16
Has anyone encountered a similar issue?
Thank you
Giovanni
Try checking whether your hardware and software requirement has been met. Ensure that you have enough free disk space to contain copies of uncompressed version installation files.
You could try to download and install the latest Quartus Pro version 20.3 to see if the issue persists. Temporary turning off your antivirus software may help.
- RichardT_altera
- gbassi
Thank you for the answer!
Hardware and software requirement has been met. I have also checked disk space availability.
Quartus Pro version 20.3 installation went ok, the issue seems related to the 19.3 version.
