10 years agoQuartus Prime Lite IP Cores compiling
Hi, My name is Eloy Navarro, and I have a doubt about compiling with Quartus Prime.
The fact is that I was used to Ciclone III family with Quartus 10.1, having no problems to compile and program IP Cores with time limitation. Now I have moved to Cyclone V and I'm unable to compile a project with IP Cores (FFT is the one I'm trying). I am working with Quartus 15.1 Lite Edition and a BeMicro CV A9 as target board. The user guide (ug_fft.pfd) tolds to manually add .qsys .qip and .sip. Once attached, the compilation exits with errors ("can't generate netlist output files because "..." is an OpenCore Plus time-limited file." and "can't generate netlist output files because the encrypted file "..." is not available.") I have not added anything else. I don't know if these errors are related with something missing, licensing, libraries or maybe I'm doing all wrong in this new Quartus. Thanks in advance and Best regards, EloyNo RepliesBe the first to reply
