gchadwick
6 years agoQuartus Prime Lite 20.1 reports a compile error on valid systemverilog generate block syntax
The following system verilog produces an error in Quartus Prime Lite 20.1:
logic [7:0] foo;
for (genvar i = 0;i < 8; i++) begin : g_test
assign foo[i] = 1'b0;
end
The error seen is:
sstrell
6 years agoJust to verify, in the project settings, which version of Verilog have you selected for the compilation (under compiler settings)? Perhaps you have it set to an older compiler version that is causing the issue.
#iwork4intel
gchadwick
6 years agoThe language version is set to system verilog (under Assignments->Settings->Compiler Setting->Verilog HDL Input)
