ASWATHYV_V_11
5 years agoQUARTUS PRIME LITE 18.1 EMBEDDED MEMORY
Please help us to find the simulation debug settings to set the breakpoint to generate the embedded memory in QUARTUS II PRIME LITE 18.1 EDITION.
RichardT_altera
5 years agoI don't quite understand your questions. Could you help to clarify your question?
Do you want to set a breakpoint? Or to generate embedded memory?
Which simulator tool are you using?
You may refer to the user guide below on how to use the Embedded Memory:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_ram_rom.pdf
