RK1177
5 years agoQuartus prime lite - Can't create work directory
I just started using quartus lite, so I can't understand some technical words.
I'm glad if I get your support.
I opened "New Project Wizard" and filled in the blanks as followings.
Q. Wh...
- 5 years ago
If you don't have access to writing to the directory in Windows, you might get this error. Try putting the project directory at a location you have access to.
sstrell
5 years agoIf you don't have access to writing to the directory in Windows, you might get this error. Try putting the project directory at a location you have access to.
- RK11775 years ago
Hi sstrell, thanks a lot for your reply.
I changed the location from "C:\intelFGPA_lite\20.1\sample" to "C:/intelFGPA_prj/20.1/sample".
Then somehow I successfully created the directory!
Thank you for your advice.
