KCHUN4
8 years agoQuartus Prime Infinite Compile
I use Quartus Prime Standard Edition 17.1.1. OS is Winodws 10 Pro. CPU is Intel i9-7900X. When I try to compile in Quartus, Sometimes, It was Infinite Compile at 'Analysis & Synthesis' Step. ...
AnandRaj_S_Intel
8 years agoHi,
"In the case, I try PC Reboot, so then this problem is improved"
Issues may be related to the RAM memory in CPU based on above statement.
Recommended Physical RAM for Intel Devices 17.1 based on the device family given in below link under "Memory recommendations"
https://fpgasoftware.intel.com/requirements/17.1/
If you have enough RAM.
- Can you share project details (Like Device, IP used and its settings )?
- Check with simple design, If you are facing same issues.
- If possible can share the design?
Anand Raj Shankar
