TerraX
4 years agoQuartus Prime GXB passthrough pins using Transceivers SDI_ii
I'm using a Cyclone V and trying to pass through an HD-SDI signal from a GXB Rx pin -through the FPGA- to a GXB Tx pin. They are on the same Bank. I am new to the SDI protocol and would like some tip...
skbeh
Contributor
4 years agoPer my understanding from your description, you want to implement SDI-SDI loopback.
The SDI II duplex loopback example design for Cyclone V GT is available below for reference.
This Design Example SDI II IP design support loopback.
