Quartus Prime Floating License
Hello
Welcome to Intel forum. But before setting up license, would you kindly help check, whether your machine is supported or not (OS) by referring to link below:
https://www.altera.com/support/support-resources/download/os-support.html
Make sure the port used by license server or vendor daemon is not blocked. The port number is required for Windows systems and should be outside of the 27000-28000 range and be unique on the machine. The following example shows how to specify port numbers in a floating license file. example, specify ports 1800, 1801, and 1802.
SERVER myServer 0123456789ab 1800
VENDOR alterad ./alterad port=1801
VENDOR mgcld ./mgcld port=1802
Please stop and restart the server. You need to allow the firewall access to the port number from both server and client machine.
You can also refer to link below for more detailed instructions for Setting up a floating network license server (page 37 of 59):
You can also refer this following YouTube for license setup. https://www.youtube.com/watch?v=Ob9ei5lMgG
You can also refer to this following YouTube on Setting up and debugging Quartus floating licenses.
https://www.youtube.com/watch?v=llLaWatUbe8
Let me know if this information is helpful.
Please tell me where is the license server or vendor daemon. I am not using any external server. I have simply installed license in my laptop machine. Do i need an external server?
Also, https://www.youtube.com/watch?v=Ob9ei5lMgG This link in unavailable
