Quartus Prime desktop window
Hi Kim,
You can change the screen resolution by using xrandr command. Try to make your resolution as the requirement and see if it resolve the issue. Refer to link below to change resolution using xrandr.
https://askubuntu.com/questions/890839/how-can-i-change-resolution-using-xrandr
My screen resolution is max'd out at 1366x768.
I need to change what Quartus thinks is the default screen resolution.
If I can't move it up or scroll down to the 'apply' box it thinks my screen is taller than it is.
Again , is there an environment variable that Quartus can read to get it right.
also ,as I said before , if the minimum screen resolution for this software is 1024x768 it should work. I have xranr to 1024x768 and that shows the window even taller than it was before.
