Quartus Prime Avalon SDRAM Controller - readdatavalid never asserting
I'm currently using the DE2-115 education board and implementing the SDRAM controller. When instantiating a read (from the Avalon MM documentation, I believe read requests are pipelined), the readdatavalid signal from the controller is never asserted even when read is asserted. I have tried both leaving the address and read asserted, and de-asserting the read signal after one clock cycle. I believe all the controller ports are connected properly, but I can't be 100% sure since I don't have access to a simulator. Thanks to everyone in advance.
- AdzimZM_Altera
Hi Sir,
Do you see the waitrequest signal has been asserted after the read signal been asserted?
Do you see any difference when using burst operation?
I can assist you on Simulator (Modelsim) to simulate the design if you want.
But I need the design file and maybe some instructions.
Adzim
- AdzimZM_Altera
I'm hope you're doing well.
May I have any update on this case?
Adzim
- albertsun
Apologies for taking awhile to respond. Since the time of posting, I've transitioned to using M9K blocks instead for memory since the application doesn't have a high memory capacity requirement. I've attached a relevant snippet from my wrapper around the SDRAM controller - if that looks good, then there might've been some stray X's within a few signals.
Thanks for all the help again.
- AdzimZM_Altera
I'm glad to hear from you. Thanks for your update.
I think the wrapper looks okay.
Please let me know if you have further question on this topic.
Adzim
- AdzimZM_Altera
We do not receive any response from you to the previous reply that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
