9 years agoQuartus Prime 16.1 Lite compilation issue
Hi All,
I met a problem that my software cannot generate an 500ms counter, see my code and picture, can you help me? https://alteraforum.com/forum/attachment.php?attachmentid=13466&stc=1
/********************Test01***********************
Project Name: Test01;
Function: Just test my FPGA board
Version: 0.1
Editor: Vincent Li
Date: 2017-04-03
clk=50MHz
module test01( clk, nRST, LED );
input clk,nRST;
output LED;
parameter T500MS = 25'd24_999_999;
reg rLED;
reg Count;
always@(posedge clk or negedge nRST)
if(!nRST)
Count <= 25'd0;
else
Count <= Count + 1'b1;
if(!nRST)
rLED <= 4'd1;
else if(T500MS==25'd24_999_999)
rLED <= {rLED,rLED};
assign LED = rLED;
endmodule
Here is the problem:
else if(T500MS==25'd24_999_999) This is always true - I think you meant count? - Altera_Forum
Hi Tricky,
thank you for your reply, yes you are correct...I had corrected this morning and it works. Br
